3.6 Gbps Dual-Band Mesh WiFi
2882 Mbps (5 GHz) + 688 Mbps (2.4 GHz)
2.5 Gbps Wired Connections
2x 2.5 Gbps ports ensure max flexibility and boosted throughput; always share the highest level of internet speed with high speed Deco wifi extender booster
Wireless and Wired Combined Backhaul
Connects a wireless and wired backhaul with each unit simultaneously to improve overall throughput and reduce latency; enjoy the speed with Deco wifi extender
Multi-Link Operation (MLO)
Simultaneously send and receive data across different bands and channels to increase throughput with Deco wifi repeater, reduce latency, and improve reliability
Seamless AI-Driven Roaming
Forms a unified wifi mesh system network with built-in AI-Roaming creating the ideal Wi-Fi solution for your home
TP-Link HomeShield
Provides comprehensive network protection, robust parental controls, and real-time IoT security; ensure the secure and fast internet with the Deco wifi booster
Universal Compatibility Wifi 7 Mesh
Backward compatible with all WiFi generations and works with any internet service provider (ISP) and modem
