Quicklinx: | B0QGWS00 |
Mfr#: | Archer D2 |
TP-LINK's Archer D2 AC750 Wireless Dual Band Gigabit ADSL2+ Modem Router is a combined wired/wireless network connection device with integrated wireless router and ADSL modem, reducing hassle of configuration and saving space. Featuring a variety of features and rich functionality, Archer D2 is the perfect hub of your home or business network.
802.11ac - The Next Generation of Wi-Fi
TP-LINK's Archer D2 comes with the next generation Wi-Fi standard - 802.11ac, backward compatible with 802.11n and 3 times faster than wireless N speeds. With higher power efficiency and robust security, 802.11ac is the perfect way to accelerate a home multimedia network and solve congestion that multiple devices may cause.
750Mbps Concurrent Dual Band - More Bandwidth, Less Interference
With 433Mbps wireless speeds over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, Archer D2 offers you the flexibility of two dedicated networks and ensures amazing wireless performance. Simple tasks such as sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
Broad Wi-Fi Coverage and Targeted Connection
Featuring three detachable external antennas and high power amplifiers, Archer D2 is able to boost Wi-Fi coverage throughout your home. Advanced Beamforming technology enables Archer D2 to focus WiFi signal to connected devices, delivering a more targeted and highly efficient wireless connection.
Full Gigabit Wired Connections - Ultrafast Data Transfer Speeds
With one Gigabit LAN/WAN port and 3 Gigabit LAN ports, the Archer D2 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
Multifunctional USB Port - Easy Storage and Sharing
Using the Archer D2's multi-functional USB 2.0 port, you can share a printer with multiple computers and devices on your network and can also share files & media at home or via the FTP server while away from home.
Interchangeable LAN/WAN Port - Versatile Connectivity
The Archer D2 supports ADSL or Ethernet WAN connections (EWAN), which allows users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
Easy Setup
Included in the resource CD, TP-LINK's optimized configuration utility can help you complete the entire software installation and wireless network settings in just a few minutes. It's worth mentioning that with built-in intelligent auto-detection, Archer D2 is capable of automatically figuring out which connection type to use in a flash, saving you the trouble of searching for your connection information type and speeding up the setup process.
Guest Network
Guest Network Access provides secure Wi-Fi access for guests sharing your home or office network in a controlled manner without needing to expose private Wi-Fi access codes or other personal data.
IPv6 Supported
Archer D2 supports IPv6, which is the foundation of the next generation of the Internet and enables a range of new services and improved user experience.
