Super Fast Transfer Speeds Providing a Superior WiFi Experience
Archer C8 comes with the next generation 11ac Wi-Fi standard, offering total data transfer speeds achieving up to 1.75Gbps, with 1.3Gbps over the clearer 5GHz channel, and 450Mbps over the 2.4GHz Channel. Ultra-fast 800MHz dual-core CPU function as a great `heart' for fast, stable and responsive performance with Wi-Fi, Ethernet and USB devices. Whole home coverage with excellent Gigabit WiFi are ideal for bandwidth intensive applications such as HD video streaming and online gaming, allowing you to enjoy a super-fast connected home.
Greater Coverage and Reliable Wi-Fi
Archer C8's 3 dual band antennas with high powered signal amplifiers guarantee continuous Wi-Fi speeds to all your devices while boosting Wi-Fi coverage throughout your home.
Beamforming Technology for Efficient WiFi
Archer C8's beamforming technology locate your connected devices and boost wireless signal strength in those directions, delivering a more targeted and highly efficient wireless connection.
Dual USB Ports for Easy Sharing
With one ultrafast USB 3.0 port and one USB 2.0 port, you can easily access and share a printer locally and files & media with networked devices or remotely via the router's FTP server. The USB 3.0 port provides up to 10x faster USB hard drive access than legacy USB 2.0 connections.
Gigabit Wired Connections for Ultrafast Data Transfer Speeds
Full shielded Gigabit WAN-LAN ports can achieve blazing WAN to LAN throughput of up to 1000Mbps. Archer C8 is a powerful hub to support a robust and extremely fast wired network.
Modern and Elegant Appearance
Archer C8's novel shape catches people's eyes with its beauty, decorating a modern home. With numerous ventilation holes in the back, uninterrupted high speed performance is guaranteed. With gentle curves, excellent crafting and remarkable quality, its design exudes fashion and elegance.
