8 of the 11 auto-negotiation RJ45 ports (port 1 to port 8) of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af/at compliant powered devices (PDs).
Overload arrangement
TL-SL1210MP has the priority function which will help protect the system when the system power is overloaded. If all PoE PDs' power consumption is too large, a priority will be arranged among the PoE ports, then the system will cut off the power of the lowest-priority port.
Intelligent power management
Priority (port 1 > port 2 >...> port 7 > port 8): this function will help protect the system when the system power is overloaded. For example, ports 1, 2, 3 and 5 are using 30 W (maximum power per port is 30 W); the system power now is 120 W in total. If there is an additional PD inserted to port 4 with 30 W, the system will cut off the power of port 4 because of the overloaded power, this means port 1, 2, 3 and 4 will use 30 W, no power will be supplied to port 5.
Easy to use
TL-SL1210MP is easy to install and use. It requires no configuration or installation. With desktop and wall mountable design, outstanding performance and quality, TL-SL1210MP is a great selection for expanding your network.
