The Tecra Z50 is ready to meet your business demands. Starting at a light 1.7 kg and highly robust, it's the perfect companion as you move between desks and meeting spaces. Even without an extended battery, you get a long-lasting on a single charge. And if you're working in a patch of sunlight, you won't see any glare on the large 39.6 cm (15.6") non-reflective HD screen. So it's really convenient to type emails or create documents at any time - even in dimly-lit conditions, using the illuminated keyboard.
Made for multi-tasking
With powerful processors, the Z50 has all the power and drive you need to move between multiple tasks. Tecra Z50 offers plenty of storage, faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
Fully connected
The Tecra Z50 is packed with full-size ports, so you won't need any special adapters to work more flexibly. You can transfer data to other devices much faster, using three of USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Plus, it's easy to connect to monitors and displays with RGB. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. Connecting to your peripherals is fast and simple with the optional docking solution, which aligns with the other models in Toshiba's latest business line-up. The SD card slot boosts storage too.
You can depend on it
The ultra-durable Tecra Z50 was designed to withstand the pressures of professional life and meet Toshiba's quality standards. With its light yet strong magnesium chassis, the Z50 is highly durable too, so you can be sure of a better return on your investment.
Secure and easy to manage
The Z50 is built for business, and comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z50 needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The standard fingerprint reader makes it easy and secure to log on to your PC too, while the 3D sensor knows to take care of your data if your laptop falls.
Business improvements all round
Toshiba is constantly improving its models to help meet more of your business needs. So silent cooling and better speakers were added to the design to make the Z50 more durable and user-friendly. With a larger HD screen and improved backlit keyboard, plus larger Accupoint and touchpad, it's easier to view your laptop and navigate your way around it too.
Synergy across devices
The Tecra Z50 shares many features with the latest business line-up from Toshiba, to ensure consistency across your company - no matter which models you choose. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z50 also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility. All Toshiba laptops share the same software image, for easy customization in one go. Plus, the fingerprint reader, non-CSV display, webcam, magnesium chassis, Accupoint and docking connector all come as standard too.
