With a combination of performance and reliability, the 38.1cm (15")
Satellite Pro R50-C notebook is ideal for any professional environment. Not
only can you feel confident in the fast processing speeds of the device's
Intel® Core™ architecture, but you can also feel reassured by a solid design
that's built to withstand the pressures of daily use. Add to that a heavy
typer keyboard and a 3D sensor for data protection and you have a device
that's built to last. And with the latest integrated Intel® Premium Wi-FI
and LAN, the Satellite Pro R50-C won't date quickly either - making it more
cost effective in the long run. The benefits don't end there: the Satellite
Pro R50-C has an advanced system that supports silent working, a matt LCD
screen for sharp visuals and a full size keyboard - making it both user- and
office-friendly. Meanwhile, a Kensington lock offers security for the device
itself, and pre-installed McAfee software provides protection for all your
data on the inside. You can even take control of your power consumption
using the pre-installed Toshiba Eco Utility. As the starting point in a
wide range of Toshiba business devices, the Satellite Pro R50-C is the
affordable way to meet all your professional needs.
5th Generation Intel® Core™ i3-5005U Processor (2.00 GHz, 3rd level cache:
3MB)
Windows 8.1 64-bit (pre-installed) free upgrade to Windows 10
39.6cm (15.6") Toshiba HD non-reflective High Brightness display with LED
backlighting and 16 : 9 aspect ratio, internal resolution: 1,366 x 768
500 GB (5400 rpm ) SATA HDD
4GB System memory DDR3L RAM (1,600 MHz)
Slim DVD Super Multi (Double Layer) drive
Intel® HD Graphics 5500
1 year European Carry-in warranty
