Quicklinx: | 9QTJWS00 |
Mfr#: | PSSG0E-004002EN |
DESIGNED FOR YOUR BUSINESS
Regardless of your business' size, this slim, smart and reliable laptop will help to meet all your requirements. Feature-rich yet reasonably-priced, Toshiba has put more into the 39.6 cm (15.6") Satellite Pro R50-B, so you can get more out. It's more reliable, thanks to a durable design that's ready to take on the pressures of your working life. It offers more connectivity for the freedom to work how you want to - whether that's using office peripherals via two USB 3.0 ports, or making a presentation on an external display with HDMI or RGB. Plus, the laptop comes with more ways to manage your workload - from fast network access through Gigabit LAN and Intel® Wi-Fi to a choice of powerful Intel® processors. And with a 39.6 cm (15.6") non-reflective HD display, you see every detail of your content in high definition. Wherever your working day takes you, the Satellite Pro R50-B was designed for your business.
Every element is designed to meet the needs of small and medium
organisations like yours. By putting more into the Satellite Pro R50-B, Toshiba has made sure that you get more out of it - for an improved experience that delivers added value every time you use it. So the port layout is on the side of the laptop for easier access. The hinge has been positioned in a way that brings you added stability. And the black colour design with thin stripe doesn't just look smart, it offers increased resistance to fingerprint marks too. Designed, engineered and manufactured by the trusted partner for SMB, the Toshiba Satellite Pro R50-B is professional through and through.
MEETS THE DEMANDS OF YOUR DAY
You can rely on your Satellite Pro R50-B to meet the demands of your busy working day. It's already passed a combination of stress tests carried out by the independent German test institute, TÜV Rheinland®. Known as the Highly Accelerated Life Test (H.A.L.T), it mimics the lifecycle of your laptop by subjecting it to levels of vibration, heat, and pressure. So you know the durable R50-B can withstand unpredictable situations and weather conditions - ideal when you're on the move. Add to that the device's high stiffness design, which reduces bending, and you've got a machine that can stand up to daily use, time and time again. In fact, we're so confident in the quality of the R50-B that it even comes with a 1 year Toshiba
Reliability Guarantee.
SMART STYLE
There's a lot more to the Satellite Pro R50-B than a slim, stylish and durable chassis. Open up the lid to reveal the tiled keyboard with numeric keypad, and you're all set to be more productive - without the need to plug in an external keypad. The full-size port layout includes RGB and HDMI too, so you won't have to carry adapters to connect to an external display. Plus, there's a 39.6 cm (15.6") non-reflective HD screen, so you're always free to focus on your business-critical content in clear high definition. With no glare to worry about, you can type emails or create documents in the office, outdoors or wherever's convenient.
MADE TO BE ON THE MOVE
With a sleek but sturdy design, the Satellite Pro R50-B is the portable office you will want to take everywhere. At just 2.3 kg, and only 24 mm thin, its slim chassis is as durable as it is stylish - and was made to be easy to carry and use. Essential for a busy working life that's constantly moving between your home, office and meetings, this business laptop has the flexibility, speed and strength to switch from task to task in any location.
PROFESSIONAL PERFORMANCE
The Satellite Pro R50-B comes with a variety of powerful processors for fast responses - and Intel® HD graphics 4400 for a smooth graphical performance. A High Speed HDD* is available to help you store your business files and critical data safely too. And with a removable, long-life battery, you're free to work wherever your business takes you.
SECURITY MANAGED
With Trusted Platform Module (TPM) secure hardware* on selected models you can be sure that your sensitive business data stays safe. The Satellite Pro R50-B also comes with a HDD 3D sensor for permanent data protection - and a 30-day trial version of McAfee Livesafe security is pre-installed to protect you from the first boot-up onwards.
BETTER CONNECTED
Whether you're working in the office, at home or on the way to a meeting, you can make the most of best-in-class connectivity to share information between devices. The Satellite Pro R50-B comes with Bluetooth® 4.0, plus Gigabit LAN and Intel® Wi-Fi® for fast network access. With one full-size HDMI port and RGB, you can easily expand your viewing area over two screens or present documents on an external display. And with two USB 3.0 ports and one USB 2.0 port, you have all the flexibility you need to connect to office peripherals, right when you need them.
