The 38.1 cm (15") Satellite Pro A50-C is designed to help professionals be
more productive. From its premium components, to its solid build, you can
depend on the laptop to provide support day in, day out - and we're so
confident in its quality that every model comes with our Reliability
Guarantee. This means in the unlikely event that your laptop breaks, we'll
give you a full refund and a free repair* - so you'll be back up and running
quickly, with minimum disruption. But that's not all. With the Satellite Pro
A50-C, you're able to choose a configuration that best suits you and your
needs. There are several combinations of powerful Intel® CoreTM processors,
storage options, and display resolutions to select - making it easy to find
your ideal business laptop. In fact, everything about the Satellite Pro
A50-C has been developed with professionals in mind. The premium interior
components deliver smooth performance and connectivity, while the
high-clarity non-glare screen and full-size keypad mean you can always work
to your full potential - enabling you to be more productive, more of the
time.
5th Generation Intel® Core™ i7-5500U Processor with Intel® Turbo Boost
Technology 2.0 (2.40 / 3.00 Turbo GHz, 3rd level cache: 4MB)
Windows 8.1 64-bit (pre-installed) free upgrade to Windows 10
39.6cm (15.6") Toshiba TruBrite® Full HD TFT High Brightness IPS display
with LED backlighting, 16 : 9 aspect ratio, internal resolution: 1,920 x
1,080
1 TB (5,400 rpm) SATA HDD
8GB DDR3L RAM (1,600 MHz)
Slim DVD Super Multi (Double Layer) drive
NVIDIA® GeForce® 930M with NVIDIA® Optimus™ Technology, 2GB dedicated VRAM
1 year European Carry-in warranty
