The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its non-reflective HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going all day, you're never interrupted by the need to find a socket and plug in. Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will not let you down. The Satellite Pro A30-C comes with a range of dongle-free connectivity capabilities - including HDMI for making presentations, three USB 3.0 ports for saving and sharing content at speed, and Intel premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features a full-size SD card slot. These features are complimented by a Full HD webcam and noise canceling dual mics that make chatting via Skype easier than ever. Although the Satellite Pro A30-C is super-mobile, it never compromises on performance. That's because it's built with efficient components. With the A30-C, you can get things done as fast as you need to - making it perfect for working between meetings, or getting your essay done as your deadline approaches.
