The Portégé Z30-C was made to move. Ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting.
With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster. The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards.
