The Portégé Z30-C was made to move. Ultralight and highly robust, with a capacitive battery, it's the perfect companion to take on your business travels. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective high-definition screen with LED backlighting. It's really convenient to type e-mails or create documents, in or out the office - even in dim conditions, using the illuminated keyboard. With its powerful processor, your laptop has all the power you need to multitask on the move or in the office. And with a high-performance drive inside, the Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot up to the minute you shut down. There's no compromise, so you can run all of your business applications with ease. The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using USB 3.0 ports or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly, so you can be more productive anywhere.
