The Portégé Z30-C was made to move. Starting at an ultra-light 1.2 kg and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get a long-lasting 15.5 hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 33.8 cm (13.3") non-reflective HD or Full HD screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office - even in dimly lit conditions, using the illuminated keyboard.
The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using all three USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. Connecting to your peripherals is fast and easy too with the optional docking solution, which aligns with the other models in Toshiba's latest business line-up.
