Toshiba design, build and ship every business device from their own factory. The Portégé X30-D, at only 15.9 mm thin and 1.05 kg in weight, powers through your workload with the latest Intel Core U Series CPU, and doesn’t overheat, thanks to our new Hybrid Air Cooling technology – so everything runs fast, and runs smoothly, even in a sleek and light chassis.
Security, assured
The security features you need make the Portégé X30-D the device you can trust. Built on our unique in-house BIOS, we add two-factor authentication including IR-based Windows Hello and built-in fingerprint reader, a magnesium chassis and a slot for the optional Toshiba Slim cable lock for physical security – plus an optional smartcard reader. Then we test everything with a Highly Accelerated Life Test simulating 3 years' usage, and subject our PCs to MIL-STD 810G testing.
For however you work
Every detail is built with you in mind – for comfort and productivity. Prefer Accupoint or glass-finished touchpad? All models feature both for smooth operation. On models equipped with a non-reflective touchscreen, brand new In-Cell Touch technology enables you to navigate and interact with content without compromising on the slim design of the device or the clarity of the display. And all models feature a non-glare display and enlarged backlit keyboard for clear working in any environment. It all adds up to comfortable all-day working.
Productivity unleashed
Streamlined design doesn't mean throttled-back performance. Through our engineering expertise, we have been able to cram the latest, highly performant technology into this amazingly thin (15.9 mm) and light (1.05 kg) chassis. Under the covers in this honeycomb-structured magnesium design you will find the latest Intel Core U Series processors, twin USB Type-C Thunderbolt 3-enabled ports for extendable connectivity, however you work – plus DDR4 and PCIe SSDs for blistering perfomance. Alongside the hardware, support for PXE, vPro, SCCM, and WMI commands makes managing your laptop – and your workload – easy.
Content that fills a room
For the meetings that matter, the Portégé X30-D is equipped with the hardware to do your content and media justice. Harman/Kardon speakers with DTS sound produce crisp, clear music or video audio that really fills a meeting room, and the HDMI port means you can share on-screen content on a larger display or TV. Finally, dual microphones make conferencing and collaborating on Skype or using voice-enabled features like Cortana easy and effective. The optional addition of a Toshiba Thunderbolt 3 dock opens presentations to dual screens in stunning 4K resolution.
