If your work demands cutting-edge detail, you'll find Toshiba's elegant dynadock 4K, with pristine Ultra HD or dual screen Full HD, the smartest way to streamline your life. With dynadock 4K you can simply plug in any notebook using a single cable - or effortlessly connect all your office and mobile needs, including your mouse, keyboard, external drives, HD TV, monitors, headphones, sound system, mobile phone and microphone. The stylish yet practical design means it can be placed vertically or horizontally, so you can keep your workspace neat and clutter-free. The dynadock 4K has six USB 3.0 ports, offering speeds up to ten times faster than USB 2.0 to ensure functionality won't be compromised - quite the opposite. Four ports are located on the back, while two are conveniently positioned on the front - complete with Sleep-and-Charge technology. That means your docked devices are fully charged and ready for action each morning. Premium Gigabit LAN ensures you have seamless network access across each device. As well as DisplayPort, the dynadock 4K also supports monitors with DVI-I or HDMI ports. That means that including the host PC monitor, the dynadock 4K enables you to use three high resolution displays at once - so you have ultimate flexibility in your media.
