Put the Toshiba N302 memory card in your digital camera or your mobile device and expand your storage. You can take many pictures with your smartphone or store songs and videos.
Great for enthusiastic photographers, this memory card provides the speed and capacity you need to catch the perfect moment in Full HD.
Secure your files
With the Toshiba write-protect feature, you can prevent accidental overwrites. Also, no worries at the airport security check, the card safely protects your precious memories from the radiation of the security scanners.
