Toshiba's L200 Laptop PC internal hard drive is designed for everyday laptop users and gamers, providing a convenient and reliable way to expand the storage capacity of your notebook computer or games system.
The L200 delivers large storage capacity in a compact 2.5-inch form factor, allowing you to hold more game data and files on the go.
Optimized cache allocation during read/write provides high-level performance in real time. The L200 includes internal shock sensor and ramploading technology to help protect your drive and data from harm. So you can work and play as much as you like - wherever you are - without worrying about your data.
The L200 is designed for low power consumption compared to 3.5-inch hard drives, to help optimize the device's battery life. Also, the drive's quiet operation (compared to 3.5-inch hard drives) makes it an excellent storage solution for game system and mobile computing applications where capacity, power-profile, and reliability are critical.
