BOOST YOUR SPEED AND PERFORMANCE
Boosting your daily boot-up speed and improving performance has never been easier. Upgrade your PC with an A100 Solid State Drive based on Toshiba's 3-bit-per-cell flash technology and experience high-speed boot up, fast system responsiveness and silent operation.
PERFORMANCE FOR EVERYDAY USE
Upgrade to a fast, efficient Toshiba A100 Solid State Drive with capacities up to 240 GB thanks to 3-bit-per-cell flash technology. A solid state drive reduces OS boot time and speeds up your computing system responsiveness rates by leaps and bounds. That's so you can enjoy more of what you want to browse and to create.
SPEEDY BOOT-UP AND PERFORMANCE
The SSD A100 uses 3-bit-per-cell flash to maximise storage capacity, without sacrificing speed. Thanks to advanced-speed and SLC Write Cache technology your system will be more responsive. From the first boot, you’ll experience speedier web browsing, emailing, media playback and more.
ONE STEP AHEAD
Trim Support keeps write speeds high by emptying unneeded stored data in advance. When new data needs to be stored, all is clear for swift operations.
LINING THINGS UP FOR MORE SPEED
Native Command Queuing (NCQ) realigns commands on the fly to optimise SSD access. This further accelerates the speed of data read/write performance.
QUALITY YOU CAN TRUST
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high-quality technology. Toshiba SSDs are based on NAND Flash technology and incorporate Toshiba controllers to achieve industry-leading levels of performance and reliability. Not only that, we are so confident of the longevity, we back it up with a 3 year warranty.
