Quicklinx: | 8ZZPWS00 |
Mfr#: | 22D1333B |
Perfect for small rooms or when space is limited, the 22" D1333 delivers Full High Definition image quality with the convenience of a built-in DVD player. LED technology means you'll enjoy amazing colour, brightness and clarity, delivered in stylish slim frame design. With the reassurance of Toshiba quality, the 22" D1 Series also includes built-in Freeview digital TV access, for subscription-free access to 50 digital TV channels and 24 radio stations without the need for an additional set top box. An 8 day electronic programme guide helps you plan your week's viewing, plus enjoy video, photo and audio playback via USB, Dolby Digital Plus audio and the convenience of HDMI connectivity and PC input that make it easy to connect to other digital entertainment devices in your home.
Built-in DVD Player
The ease of DVD entertainment without the hassle of a separate unit, the built-in DVD player provides a convenient, all-in-one, space saving entertainment hub for any room. Cut down on wires, cables and remote controls - simply insert your favourite films into the DVD player built into the 22" D1 Series LED TV and enjoy. Not only can you experience DVD-quality entertainment, you can also playback JPEG photos and MP3 music files, freeing your favourite content to be enjoyed on a larger screen.
DVD player
Space saver - simply insert DVDs directly into the Toshiba 22" D1 Series LED TVs and enjoy your favourite movies and TV box sets.
Full High Definition 1080p
The 22" D1 Series supports Full High Definition 1080p resolution content. Offering outstanding picture quality and lifelike image reproduction, your films and programmes will appear crisper and more detailed, allowing you to take your enjoyment to the next level. Ideal for sports, movie and documentary enthusiasts who want to experience the most from their entertainment, this Full HD TV will be able to display HD images from any HD source.
LED Technology
The 22" D1 Series also includes an advanced backlighting system that guarantees new levels of picture clarity by constantly adapting to the images on the screen. Colours are made more vibrant and contrast between light and dark is more pronounced, providing dramatically improved performance, whilst overall energy consumption and the thickness of the TV is also reduced. Response times are also much quicker than conventional CCFL LCD TVs, so fast moving image quality is improved.
Built-in Freeview Digital TV
Built-in Freeview is the easiest way to enjoy digital TV for free. There are to up to 50 digital TV channels and 24 radio stations. No subscription, no contract, no fuss - with a Freeview tuner you can be sure your TV is compatible with the digital switchover, allowing you to enjoy your favourite shows in digital quality for years to come.
AMR100 Picture Processing
Toshiba's AMR100 picture processing technology provides vivid images and ultra-smooth moving picture quality. Motion blur is drastically reduced in fast moving pictures, such as action sequences or sports, delivering more defined movement on screen.
USB Playback - View Images, Video and Audio
The built-in USB connectivity provides an easy way to playback your compatible videos, music and photos directly via your TV. Simply plug a compatible USB drive into one of the two USB ports on the TV and select the file you want to play.
8 Day Electronic Programme Guide
Never miss your favourite shows again - the 22" D1 Series includes a built-in electronic programme guide showing the digital TV programmes scheduled over the next 8 days. Plan your viewing in advance or easily browse the full range of Freeview channels - no listings magazines needed.
HDMI and PC Inputs
The included HDMI input makes it easy to connect to a Blu-ray, DVD player, gaming console or many other devices via a single cable, allowing you to easily enjoy the best HD content available. Need a larger screen for your laptop? The PC input allows connection to a laptop or PC so your TV doubles as a PC monitor.
Wall Mountable
This TV is ready to mount on your wall. A wall mount with fitting dimensions of 75 x 75 will be compatible with this TV.
Dolby Digital Plus
Dolby Digital Plus, or Enhanced AC-3 (E-AC-3), is an advanced surround sound audio codec designed specifically for evolving media, ensuring that you get the renowned Dolby cinema experience from all your entertainment. Dolby Digital Plus is based on core Dolby Digital technologies, the established standard for cinema, broadcast, and home theatre surround sound.
Dolby Digital Plus Benefits:
Up to 7.1 discrete channels of clear, high-fidelity surround sound
Ideal audio codec match for HD video codecs
Dolby cinematic audio experience for content across all media
Full 5.1-channel interactive experience for Blu-ray BonusView and BD-Live
Full 7.1-channel support for primary Blu-ray soundtracks
Easily converted to Dolby Digital, enabling compatible playback through current Dolby Digital equipped systems
