TomTom GO is the smart, easy-to-use, portable navigation solution. Switch it on and GO. The crystal-clear widescreen display, 3D graphics and voice instruction help you ?nd your way to any address in the United States and Canada. A few taps of the screen get you going. Pick a destination, choose the type of route, and it guides you door-to-door. The built-in Bluetooth connection lets you easily make or receive calls hands-free. And with TomTom PLUS the GO can re-route you around traffic jams and alert you to bad weather. Easily control your iPod directly from your TomTom GO. Just tap the GO's widescreen to see, select and play your favorite iPod tunes. The home dock lets you connect to your PC for itinerary planning and downloading maps, voices, and more. The portable, widescreen TomTom GO is the smart and easy choice for every car, every trip, everyday.
