Keep your technology secure and reduce the chance of theft with this clever and sturdy combination security lock. Designed for devices that feature the traditional T Bar style security slot. Easy to engage and remove.
Constructed from high-strength steel, this security cable lock is designed for long-lasting durability and resistance to tampering, providing peace of mind for the user.
Customizable security
The combination lock functionality allows users to set their own 4 digit code, offering flexibility and control over access while minimizing the risk of forgotten keys.
Enhanced safety
With a robust T-bar lock feature, this cable lock provides a secure connection that is less susceptible to manipulation and forced entry, ensuring belongings remain safe.
Surface protection
Thanks to its vinyl-coated exterior, the lock safeguards surfaces from scratches and damage while providing a comfortable grip for users during operation.
techair - security cable lock
Security cable lock
Silver
Product Material
Steel
Length
2 m
160 g
Combination lock, T- bar lock, 4 digit code, vinyl-coated
Security cable lock
Product Material
Steel
Length
2 m
160 g
Silver
