The Targus Wireless Optical Laptop Mouse is the perfect solution for users on the move or those who prefer a clutter-free workspace. Designed to fit comfortably in any size hand it provides perfect support for extended periods of use, whilst the integrated scroll button allows you to scroll up or down through spreadsheets or browse the internet. The high definition optical sensor provides enhanced precision and accuracy, and extended battery life of up to 6 months.The low power indicator light will provide you with an early warning for when the batteries need changing. The mouse also comes with a micro USB receiver which is small enough to leave permanently plugged into your computer or using the built-in Stow-N-GoTM technology the USB receiver can be easily stored away into the mouse itself. *Battery life based on average usage per day and computing conditions.
