We've got you're back covered
Simple, minimal, Vucomplete adds a protective backing to your new iPad® to shield it from scratches.
If you want to protect your treasured new iPad®, but don't want to sacrifice its unique style, VuComplete™ protective back cover is just the thing. It fits snugly around the back and sides of the iPad® and can be used in conjunction with the existing Apple® Smart Cover. The high-end, weaved texturing on the exterior is wipe-able and easy-to-clean, and it also allows the Apple® logo to remain visible.
- Apple® Smart Cover Compatibility
- Strong, Rigid Backing
- High-End Textured Material
- Visible Apple® Logo
