For a slim iPad smart case, look no further than the Targus Versavu 360-degree iPad Air 2 case. The perfect fit cradle holds your iPad Air 2 securely, while the deep foam grooves provide angles for comfortable viewing and typing. Our 360-rotating technology allows you to seamlessly switch from landscape to portrait effortlessly. Made of a polyurethane material, the slim design keeps your device clean and protected while easily traveling with you. The discreet cord closure makes sure that your device stays in place when you’re on the move. The Versavu 360° fits conveniently in your bag, so you’ll never have to worry about your iPad weighing you down.
