tado Smart Thermostat - Starter Kit (v3)
Introducing the new Smart Thermostat - Starter Kit (v3): More comfort, better control and platform connectivity.
With multi-room control and the new heating algorithm, tado° can save even more on your heating costs and make life more comfortable. An improved interface on the thermostat itself and the new Smart Schedules in the app make control of your heating even easier.
The tado° Smart Thermostat uses your phone’s location to control your heating, ensuring no energy is wasted. The smartphone app gives you full control over your heating wherever you are. Experience more comfort while saving up to 31% of your heating costs.
What’s in the box?
Smart Thermostat
Internet Bridge
USB cables
Connectors
Ethernet cable
Mounting screws
Adhesive pads
Labeling for cables
Screwdriver
3 AAA batteries
How tado° controls your heating
The Smart Thermostat and the Smart Radiator Thermostats connect to the internet and control your heating system or radiators.
Location-based control - The tado° Smart Thermostat automatically turns down your heating when the last person leaves home and begins to warm up again when it detects the first person returning.
The tado° app - With the tado° app on the residents’ smartphones, tado° detects how far they are away from home and sets the temperature accordingly. You can also manually control your heating.
Integrations
The new product suite offers several integration possibilities, such as Apple HomeKit, Google Home, Amazon Echo, and IFTTT.
Make tado° part of your connected home and create scenes with Apple HomeKit. Use Siri, Google Assistant or Amazon Echo to voice control your heating and create Applets with IFTTT to connect with other applications and smart devices.
Thermostat
The Smart Thermostat can be automatically controlled via the location of your smartphone as well as manually, by schedule or on the device itself.
LED matrix display - shows current temperature and settings
Touch arrows - to manually change the temperature and other settings
Button - to activate the display, scroll through the settings and make changes
Setup - Control your heating with the Smart Thermostat
The Internet Bridge connects to the internet via your router. The Smart Thermostat and the Internet Bridge communicate via radio.
More control
tado° shows you how warm it is at home, when your heating is on and how much you are saving. You can control your heating from wherever you are with the mobile app on your smartphone or tablet.
Geolocation
tado° uses the residents’ locations to control the heating. Saves when nobody is at home and heats when the first person heads back.
Save money
tado° cuts your heating bill by up to 31%.
Report overview
The report shows you the home temperature throughout the day and your savings with tado°.
Weather forecasts
tado° adapts your heating to the weather forecast, making use of natural heat to save energy.
Effortless
Easy to install, intuitive to use and automatically adjusts the heating to your lifestyle.
Heating error messages
tado° informs you about issues with your heating system and provides direct assistance and advice.
Building characteristics integration
Every home is unique, tado° gets to know your building and learns the most efficient way to heat your home.
Flexible use
tado° adapts to your needs: automatic heating control, schedules or manual control.
Self install
You can easily install the Smart Thermostat yourself. Our online installation service gives you detailed step-by-step instructions for your heating system.
Open Window Detection
The Open Window Detection recognises sudden drops in temperature or humidity when a window is opened and turns the heating off to save energy.
tado° energy savings guarantee
Our promise
Not sure if tado° works for you? You can now enjoy a risk-free trial: If at any point you are not convinced, or tado° hasn’t saved enough during the first year, you may return the product and get a full refund.
Requirements:
• Applies to all heating products purchased after September 1 2016. The Smart AC Control, Smart Thermostat Starter Kit (v2) and the Connector kit (v1) products are excluded.
• copy of original receipt (tado° or retail partner)
• date of purchase not earlier than 12 months ago
• minimum of 6 months use
• shipment of complete and undamaged products
• it is not required to provide any additional documentation (bills etc.) regarding energy consumption. We trust you!
This guarantee is provided by tado. Any questions, please contact tado: https://www.tado.com/gb/heatingcontrol-savings#energy-savings-guarantee.
