The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput.
DS415+ supports Synology high availability (SHA), harnessing an active and a passive server into one cluster, mirroring written data between the two units. Should the main server malfunction, the passive server immediately kicks in and takes over all running services and data. Synology Hybrid RAID allows you to optimize usage and get the most out of your hard drives, while also keeping your storage safe with data redundancy.
