- A state of the art & expandable surveillance system with 1080p HD resolution
- Set & forget by recording from 8 cameras for 160 days+ onto a 2TB hard drive
- Just add Swann’s PRO-H855™, H856™ & T800™ series cameras & enjoy High Definition recording & playback
- Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
- View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
- Connect in minutes using SwannLink ‘Peer-to-Peer’ easy network connection software
- Surveillance in the palm of your hand with live viewing on 3G/4G-enabled Smartphone & tablets including iPhone, iPad, Android devices and more using the free SwannView Link app
- Swann DVR8-4550 - standalone DVR - 8 channels
- Standalone DVR - 8 channels - networked
- Image Resolution
- 1920x1080
- Hard Drive
- 1 x 2 TB
- Hard Drive(s) Supported
- Total capacity: 4 TB
- 21.5 cm x 21.5 cm x 4.5 cm
- Country Kits
- United Kingdom
- Standalone DVR
- Video Channels
- 8
- Image Resolution
- 1920x1080
- Package Content
- DVR, external power adapter, mounting kit, mouse, 4 security stickers
- Cables Included
- Network cable - RJ-45 - RJ-45 - 1 pcs. , HDMI cable - 1 pcs.
- Country Kits
- United Kingdom
Security DVR
- Networked
- Smartphone support
Hard Drive
- Quantity Installed
- 1
- Capacity
- 2 TB
- Interface
- Serial ATA
- Supported Max Total Capacity
- 4 TB
- Video Input Ports
- BNC x 8
- Video Output Ports
- HDMI x 1, VGA x 1
- Audio Input Ports
- RCA x 1
- Audio Output Ports
- RCA x 1
- Camera Control Interface (PTZ)
- Network Port
- 10/100Base-T
- Other Ports
- USB 2.0 x 2
- 21.5 cm
- 21.5 cm
- 4.5 cm
