Optical technology. Optimal performance
The SteelSeries Ikari mice are the result of 15 months extensive research of ergonomics, technology, shape, motion, hand grip and play styles by gamers. The SteelSeries Ikari mice sets a new industry standard for input, research and co-development with professional gamers for gaming mice. The shape, materials and specifications of the SteelSeries Ikari mice are based on input from professional players from Team 3D, compLexity, mousesports, SK Gaming, Team NoA and other world-class gaming organizations, who collectively represent the world's most accomplished gamers in Counter-Strike and other gaming disciplines. The development of SteelSeries Ikari was also driven by community input and feedback from more than 5,000 gamers from the competitive gaming segment.
The SteelSeries Ikari Optical was designed as a top performer for FPS gamers. The research and development emphasized a "no nonsense" approach with proven optical technology that allows gamers consistent, fast movements without technical difficulties of any kind.
Size and weight
-Weight: 103 grams (0,23 lbs)
-Height: 36 mm (1,4 in)
-Width: 83 mm (3,3 in)
-Length: 130 (5,1 in)
Toggle On-the-fly
With "Toggle On-the-fly" we introduce an option for gamers to have 2 different sensitivity settings and switch between them with only 1 button click below the scroll wheel on the mouse. This allows you to switch your sensitivity settings quickly, whehter it's for different weapon types in FPS games or in player vs. player action for MMORPG games.
Reasonable price
To us, it's important that when we remove the "extras" in a piece of hardware, the price should follow. This is why the SteelSeries Ikari Optical is in a reasonable price range, compared to other optical mice in the market. The balance between options, price, and quality is what makes this product one of the best in its category.
Driverless, plug and play
There are no external drivers needed to configure your settings for the Ikari Optical. All you need is in the mouse itself, which makes it perfect for travel and when using multiple platforms or computers.
Buttons
1.CPI high / low switch
2.Scroll wheel & middle click
3.Right click
4.Left click
5.Left side button 1
6.Left side button 2
Maximum performance
The SteelSeries Ikari Optical mouse is designed for one thing, to perform. FPS gamers love this mouse for its straight forward no-nonsense approach to gaming. But don't be fooled by its simplicity, it's whats "under the hood" that makes this mouse and FPS gamers ultimate weapon.
LARGE GLIDE SURFACE FOR MAXIMUM CONTROL
The large glide pads underneath the mouse give it a smooth and fluent glide on any surface. This provides extra stability and reduces friction for maximum control.
We recommend to change glides regularly as they eventually get worn down. See our made to fit SteelSeries Glide Ikari.
The solution for First Person Shooters
The unique shape of the Ikari Optical was more than a 15 month long journey of design innovation and testing in order to create an optimal FPS gaming mouse. If you like a mouse that can deliver high performance with a simplistic look and feel, then the SteelSeries Ikari Optical is made for you.
Braided cord
-Gold plated USB 2.0 connector
-Anti-tangle braided cord for enhanced durability
-Cord length: 2 meters (6,5 feet)
The numbers
Frames per second: 6.500
Inches per second: 40
Counts per inch: 400 - 1.600
Maximum acceleration: 15 G
Lift distance: ~3,5 mm
Polling: 1.000 Hz
