The IREXT2 Wireless IR Extender Kit lets you extend an Infrared signal from a remote control by up to 330ft (100m).
Using a radio frequency that can operate through walls, doors, and around corners, the remote control extender lets you control your A/V devices from greater distances or even from another room. This adds configuration versatility for multi-room or outdoor applications, without having to move within range of your remote controlled device.
Extend IR remote control signals wirelessly by up to 330 feet (100 meters). The remote control extender is comprised of two units - one local IR remote extender, which accepts the incoming IR signal from the remote control and wirelessly transmits it to the second IR remote control Receiver unit positioned near the controlled device.
