Free up space with this wall-mount monitor arm and enjoy optimum viewing with the long dual-swivel extension arm. The premium design ensures smooth, effortless motion and makes it easy to re-position your display, to work in comfort or collaborate with others. The attractive silver finish complements your decor.
The wall-mount system is ideal for business, healthcare, financial or other settings, where you may want to share your screen, or for customer-facing interactive displays.
Adjust the Dual-Swivel Arm with Ease
The wall-mount monitor arm extends a full 20.4” (52 cm) and has three swivel points, offering an extended range of motion. Move the dual-swivel arms left or right, to change your screen position. You can also adjust the swivel tension.
Durable and Stable Construction
The robust aluminum design provides a stable wall-mount for your computer monitor or flat-screen TV up to 34". It’s ideal for touch-screen stability. The universal display wall mount supports VESA mount monitors (75 x 75, 100 x 100) up to 30.9 lb. (14 kg) in weight.
Adjust your Viewing Angle
Share your screen with ease. The display wall mount offers a full +180-degree/-180-degree pan, to move your screen left or right. It tilts freely +90/-15-degrees, to adjust the angle up or down. Rotate your screen for landscape or portrait viewing.
Low-Profile Design
Push the swivel arm back to the wall, so your monitor sits just 5" (129 mm) from the wall when not in use.
Tool-less Assembly
The quick slide-and-click connections make the monitor wall mount easy to assemble and saves time when setting up multiple units.
The TAA compliant ARMWALLDSLP is backed by a StarTech.com 10-year warranty and free lifetime technical support.
