Back
Accessories
StarTech.com VESA Mounting Bracket
DON’T KNOW WHAT YOU NEED? FIND IT WITH THE CONXIT WIZARD!
25 In Stock
Quantity to buy of StarTech.com VESA Mounting Bracket
£7.75
ex VAT
Add to regular buy list
Buy
Quicklinx:
J1K0WS00
Mfr#:
DOCK-NUC-VESA-MOUNT
Accessories
(1)
Back
Marketing description is not available.
Sturdy construction
Constructed from robust steel, this mounting bracket provides a solid mount for monitors and docking stations, ensuring durability over time.
Versatile compatibility
Designed to accommodate both 100 x 100 mm and 75 x 75 mm VESA mounting interfaces, providing flexibility for various monitor sizes.
Complete installation kit
Included with the bracket are a variety of screws and spacers, allowing for hassle-free assembly and secure mounting of devices.
StarTech.com VESA Mounting Bracket for NUC/Thin Clients/Docking Stations mounting component - for thin client - black
Mounting component - monitor
Mounting Components
2 VESA mount brackets
30.5 cm x 12 cm x 0.15 cm
100 g
Recommended Use
Thin client
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Steel
Package Content
4 x M3x15 screws, 4 x M3x5 screws, 4 x M4x5 screws, 4 x M4x12 screws, 4 x M4x20 screws, 4 x M5x12 screws, 4 x M5x20 screws, 4 washers, 8 x spacers
5-year warranty
30.5 cm
12 cm
0.15 cm
100 g
Material
Steel
Package Content
AV Furniture
Mounting component
Mounting Components
Recommended Use
Thin client
Placing / Mounting
Monitor
Dimensions & Weight Details
31 cm x 12.5 cm x 2 cm / 600 g
Limited warranty - 5 years
