The 2.5GbE USB-C to Ethernet Adapter by StarTech.com provides a reliable and efficient way to connect to wired networks with ease. This adapter supports data transfer rates of up to 2.5 Gbps, making it suitable for high-speed Internet connections. Designed with an integrated USB-C cable that is 15.2 cm long, it is compact and easy to use, allowing for seamless connectivity with compatible devices. The device features an RJ-45 female connector, making it compatible with various Ethernet types, including 2.5GBase-T and Gigabit Ethernet.
Equipped with impressive specifications, this network adapter supports Jumbo frame sizes of up to 16,000, enhancing network performance. It's built to withstand a range of environmental conditions, operating between 0°C and 45°C and within a humidity range of 10 - 85% RH, ensuring robust performance under various scenarios. Additionally, this adapter is compliant with multiple standards, including FCC, RoHS, and WEEE, affirming its adherence to safety and environmental regulations, making it a reliable choice for networking needs.
