The adapter supports data transfer rates of up to 5 Gbps, allowing for fast and efficient file transfers between devices.
Durable construction
Featuring a sturdy metal housing, this adapter is built to withstand daily use and offers durability over time.
Wide compatibility
This adapter complies with USB 2.0 and USB 3.2 Gen 1 standards, ensuring it works seamlessly with a variety of devices.
StarTech.com USB-C to USB-A Adapter, USB 5Gbps, Compact USB-C Male to USB-A Female Adapter, Durable Metal Housing, M/F - USB-C adapter - 24 pin USB-C to USB
USB-C adapter
Passive adapter, up to 5 Gbps data transfer rate, metal housing
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - female
Rated Voltage
5 V
Rated Current
3 A
USB 2.0 / USB 3.2 Gen 1
USB-C adapter
Rated Voltage
5 V
Rated Current
3 A
Plated Connector
Nickel
