With support for HDR and 4K 60Hz, the USB C multiport video adapter lets you enjoy higher contrast ratios and vivid colors providing a crystal-clear video output.
Flexible video output
Create a workspace with flexible display options with this?USB C 2 in 1 adapter that lets you connect your?USB C device to a VGA or Mini DisplayPort monitor.
Tested for guaranteed compatibility
USB Type C video adapter can be used with any USB C or Thunderbolt 3 laptop or tablet. Tested and engineered to work with HP, Dell, MacBook Pro, Lenovo, iPad Pro, Surface, Chromebook, Windows, macOS and ChromeOS as well as 50+ monitors, projectors and large format displays.
Two-in-one video connectivity with travel in mind
Avoid the hassle of carrying different adapters, with a?2-in-1?USB-C monitor adapter.?The multiport adapter features both Mini?DP?and VGA outputs, you can conveniently connect your laptop to any?mDP or VGA-equipped?display. The?adapter?features a durable aluminum enclosure and can withstand being carried in your travel bag.
Astonishing 4K picture quality?and HDR
The?Mini DisplayPort?output on this?USB-C video?adapter?lets you harness the audio and?video?capabilities that are built into your computer's?USB-C?connection,?delivering?the astonishing quality of UHD to your?4K 60Hz?display. Plus, the VGA output supports HD resolutions up to 1920 x 1080, ensuring you won't have to sacrifice picture quality when connected to a VGA monitor or projector. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
Stylish connectivity for your MacBook, MacBook Pro, or any Laptop
The?USB-C display adapter?has a Space Gray housing and built-in?USB-C?cable designed to match your Space Gray MacBook or MacBook Pro. The?adapter?is compatible with?USB-C DP?Alt Mode devices.
StarTech.com USB C Multiport Video Adapter, USB-C to 4K 60Hz Mini DisplayPort 1.2 or 1080p VGA Monitor Adapter, USB Type-C 2-in-1 MDP HBR2 HDR/VGA Display Converter, Works w/ Thunderbolt 3 - USB-C 2 in 1 Adapter (CDP2MDPVGA) - video adapter - 15.24 m
Video adapter
4K support, HDR support
Length
15.24 m
Connectors
24 pin USB-C - male
Connectors (Second End)
15 pin HD D-Sub (HD-15) - female , Mini DisplayPort - female
DisplayPort 1.2
Space grey
3-year warranty
Video adapter
Length
15.24 m
Space grey
4.4 cm
1.5 cm
50 g
Connectors
24 pin USB-C - male
