DUAL-LAPTOP KVM DOCK: connect / toggle between 2 PCs on your desktop and share 2 4K 60Hz displays, keyboard, mouse and other USB peripherals; toggle between two laptops using a toggle button on the front of the dock.
SIMULTANEOUSLY CHARGE TWO LAPTOP COMPUTERS: The USB-C KVM dock charges the 2 PCs connected via USB-C (PD 3.0); The included 180W power adapter automatically provides 90W of power to the active host and 45W of power to the standby host.
GUARANTEED COMPATIBILITY: DisplayLink-certified dual-host KVM dock supports 2x displays on MacBooks M1/M2; Works with mixed OS (Win/MacOS/Chrome OS); Works with PC USB-C, TB4/3, USB-A (USB-C to A cable not included).
CONNECTIVITY: The dock features a variety of ports for device connectivity; 2x USB 2.0 Type-A HID/2x USB-A (10Gbps)/USB-C (10Gbps)/2x DisplayPort/2x USB-C/Gigabit Ethernet/audio stereo 3.5mm/micro 3.5mm host ports/2x K-Slots (Standard/Nano).
OUR ADVANTAGE: Connectivity tools included for IT pros and IT teams with Network MAC Address Pass-Through for network security, WiFi Auto Switching to improve network performance/USB Event Monitoring/Windows Layout.
