Connect a 2.5" SATA SSD/HDD to your computer using this USB 3.1 Gen 2 ultra-portable cable. Here's a fast, easy way to access data on a 2.5" solid-state or hard drive. This cable-style adapter lets you connect your laptop or desktop computer directly to a solid-state drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10 Gbps).
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD/HDD quickly with no additional accessories required. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
This cable-style adapter features a compact, lightweight design that tucks easily into a laptop bag or carrying case. Use it wherever you go to access valuable data quickly - with no external power required.
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector CapIn Stock£3.90 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack)In Stock£8.03 |
StarTech.com USB 2.0 to SATA/IDE Combo Adapter for 2.5/3.5" SSD/HDDIn Stock£22.09 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter CableIn Stock£8.95 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter ConverterIn Stock£16.11 |
StarTech.com mSATA SSD to 2.5in SATA Adapter ConverterIn Stock£16.94 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 CableIn Stock£22.93 |
StarTech.com USB 3.1 Gen 2 Adapter CableIn Stock£14.45 |
StarTech.com USB 3.1 Adapter Cable w/ USB-CIn Stock£17.35 |
StarTech.com USB 3.1 2.5/3.5" SATA AdapterIn Stock£28.95 |
StarTech.com USB C to SATA Adapter CableIn Stock£33.59 |
