Add a compact external memory card reader to your computer through USB, and charge or connect USB devices with the built-in USB fast charge hub. The FCREADU3HC USB 3.0 card reader lets you quickly mount all major media card types onto your desktop or laptop computer through a USB 3.0 port. The card reader supports the most common mass storage device formats, including CompactFlash, SecureDigital and MemoryStick cards, making it the perfect high-bandwidth solution for your photography and videography workstation.
Plus, the card reader is backward compatible with USB 2.0 and USB 1.1 computer systems, making it a great addition to any USB-enabled computer.
Plus, the card reader lets you keep your tablets and smartphones charged and ready to go, and saves you time with an integrated USB 2.0 fast charging port that charges your mobile devices such as Apple iPad & iPhone and Android devices, as quickly as if you were connected to a wall outlet. This fast charge port has been specially designed for compatibility with a wide range of tablets and smartphones.
The card reader also lets you connect additional USB 3.0 devices to your computer through the same high-speed USB host connection, with a built-in 2-port USB 3.0 hub.
