Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. The MDP2VGDVHDW Mini DisplayPort to VGA, DVI or HDMI converter offers a three-in-one solution for connecting an mDP source such as a Thunderbolt -enabled MacBook Pro / MacBook Air to a VGA, DVI, or HDMI Display. Ensuring compatibility with almost any display, television or projector, this compact and lightweight adapter offers the ideal plug-and-play solution for travel, or BYOD (Bring Your Own Device) applications around the office.
You can walk into any boardroom and be ready to connect, even if you don't know what connection ports are available. The MDP2VGDVHDW maximizes the audio/video connectivity of your MacBook by offering three different output ports, in a single compact adapter.
The three-in-one converter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200/1080p you can convert a Mini DisplayPort video source to VGA, HDMI, or DVI without sacrificing video quality.
The Mini DisplayPort converter requires no power adapter and maximizes portability by easily traveling in your laptop bag with a small footprint and lightweight design.
The MDP2VGDVHDW features a sleek white design that looks great next to your MacBook Pro or MacBook Air.
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/MIn Stock£5.82 |
StarTech.com 6 ft DVI-D Single Link Cable - M/MIn Stock£6.86 |
StarTech.com 15 ft DVI-D Single Link Cable - M/MIn Stock£13.72 |
StarTech.com 6 ft DVI-D Dual Link Cable - M/MIn Stock£6.78 |
StarTech.com 18in DVI-D Single Link Cable - M/MIn Stock£5.00 |
StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/MIn Stock£9.79 |
StarTech.com 10 ft DVI-D Single Link Cable - M/MIn Stock£7.98 |
StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP ConverterIn Stock£19.10 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/MIn Stock£6.22 |
StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI CableIn Stock£50.52 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/MIn Stock£6.09 |
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI ConverterIn Stock£24.39 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – BlackIn Stock£33.13 |
StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMIIn Stock£24.75 |
StarTech.com mDP to HDMI or VGA ConverterIn Stock£18.11 |
StarTech.com mDP to HDMI or VGA ConverterIn Stock£13.32 |
StarTech.com DP to HDMI or VGA ConverterIn Stock£15.43 |
StarTech.com mini DisplayPort to VGA DVI or HDMI AdapterIn Stock£25.86 |
