The StarTech.com USB-C SD Express Card Reader is a versatile device designed for seamless connectivity. Featuring an external aluminum housing, this card reader is durable and lightweight, making it easy to carry for on-the-go use. With its USB-C 3.2 Gen 2 interface, it supports data transfer speeds of up to 10 Gbps, enabling quick access to your files and simplifying data management.
This card reader supports both SDHC and SDXC memory cards, allowing for compatibility with a variety of devices. Furthermore, it supports microSD and miniSD formats with the use of an adapter, providing additional flexibility. Bus-powered for convenience, this reader operates without the need for external power, ensuring that it is ready when you are.
