HIGH PERFORMANCE: USB-C to DisplayPort 1.4 (32.4Gbps) adapter compatible w/ HDR/DisplayHDR, HBR3, Display Stream Compression (DSC), HDCP 2.2/1.4; 8K 60Hz (7680x4320), 5K 60Hz, 4K 120Hz & 1080p
PORTABLE DESIGN: Compact & lightweight USB-C to DisplayPort adapter is perfect for travelling; equipped with a flexible wrap-around cable & removable keychain ring that securely attaches to your bag
COMPATIBILITY: Dell XPS, Precision & Latitude, Lenovo ThinkPad X1 Carbon & Extreme, Microsoft Surface Book & Surface Laptop 3, MacBook Pro, TB3 MacBook Air, HP EliteBook, Spectre & ZBook & Chromebook
TESTED & VERIFIED: USB-C to DisplayPort video converter (male to female) compatible w/ range of 8K, 4K and 1080p DP monitors/displays incl brands like Dell Ultra Sharp, Samsung, Asus ProArt, Acer & LG
EASY TO USE: USB C to DP adapter dongle supports driverless plug & play setup & is compatible w/ macOS, Windows 10, Linux & Chrome OS; works w/ any USB Type-C or Thunderbolt 3 (DP Alt Mode) device
