Professional PC Wall Mount Bracket is designed to meet the needs of IT professionals seeking a space-saving and convenient solution for their workstation setups. The supported desktop towers widths are between 1.9 to 7.8 inches (50 to 200 mm). This heavy-duty wall mount system is constructed of a 0.09in (2.5mm) thick powder-coated SPCC steel sheets, ensuring durability and strength. With a weight capacity of up to 39.6lbs (18kg), it provides a secure mount for desktop computers. Experience effortless installation with the keyhole mounting to speed up deployment.
