            The Monitor Desk Mount for 49" Ultrawide Curved Screen by StarTech.com enhances your workspace by providing an adjustable solution for up to 49-inch displays. Constructed from a combination of plastic, aluminum, and steel, this sturdy mounting kit features a mechanical spring arm for easy adjustments. The integrated cable management system keeps cords tidy, eliminating clutter and distractions in your workspace. With a range of motion that includes pans of up to 180°, tilts from -20° to 50°, and rotations of 360°, customizing your display position to suit any viewing preference is effortless. Designed with versatility in mind, the mount includes both a C-clamp and grommet mount for secure installation on various desk types. It supports a maximum load of 20 kg and is compatible with standard VESA mount interfaces of 100 x 100 mm and 75 x 75 mm. The adjustment options allow for height, depth, pivot, and swivel adjustments to create an ergonomic setup that promotes productivity and comfort, making this monitor mount an essential addition to any workspace.
