The POEINJ1GI Industrial Gigabit PoE+ Injector provides power and data connectivity to a Gigabit PoE-compliant device over standard Ethernet cabling at distances of up to 330ft (100m), and offers redundant, wide-range DC power inputs. This injector allows you to easily connect a PoE-powered device (PD) to a non-PoE LAN switch, avoiding the cost of upgrading your switch to a PoE-enabled model.
Providing seamless power failover in the event of power dips or failures, the injector features redundant 20-57V DC (nominal 24/48V DC) terminal block power inputs. The internal DC-DC converter provides the PoE injector with high voltage output from a low voltage input (<24V DC). When used with multiple power sources, the injector also supports alarm relay contacts, which can be wired to your existing alarm circuit to give you instant notice when a power disruption occurs.
Fully compliant with IEEE 802.3at / 802.3af, the injector provides a 10/100/1000Mbps port with support for up to 30 Watt max output, and up to 60 Watts output for non-standard PoE devices.
To ensure dependable performance in harsh environments this power over Ethernet injector features a rugged, IP-30 case design with flexible DIN rail or wall-mountable installation options.
Backed by a 2-year StarTech.com warranty and free lifetime technical support.
The StarTech.com Advantage
- Maintain device operation during power disruptions with redundant power inputs
- Versatile installation options with included DIN rail and wall-mount brackets
- Operate under harsh industrial conditions with an IP-30 rated, rugged housing
Applications
- Ideal for high-power PoE+ devices requiring Gigabit speeds such as a security camera or network webcam in remote areas where a power connection is not available
- Power non-standard, high-draw PoE devices such as seasonal cameras with fans or heaters
- Industrial locations where critical equipment requires backup power
- Perfect for powering a Wireless Access Point(WAP) in a business environment
- Retail applications such as RFID readers
- Enable remote installation of touchscreens or information kiosks
