Add reliable and cost-effective 8 Gigabit Fiber Channel Long Wave connections over single-mode fiber with this SFP+ module. This HP compatible 8 Gigabit Fibre Channel Long Wave SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the HP AJ717A FC SFP+ transceiver module, as well as other major brands of networking equipment.
This 8 Gb Fiber Channel Long Wave B-series FC SFP+ provides Fibre Channel Long Wave throughput (2GFC, 4GFC and 8GFC) up to 10 km (6.2 mi.) over single-mode fiber at a wavelength of 1310nm using an LC connector. It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 8G FC SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 8 Gigabit single-mode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP AJ717A optical transceiver. The StarTech.com FC SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this FC SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a range of 8 Gigabit Fibre Channel networking devices.
