            Connect to a 4K UHD TV or monitor, using this High Speed HDMI Cable. The connector markings enable quick visual identification, distinguishing this cable from other similar-looking or unmarked HDMI cables. Eliminate guesswork and always choose the appropriate cable to support full HDMI 2.0 capabilities. The HDMI UHD Cord features gold-plated gripping connectors to prevent accidental disconnections. The gripping connectors attach securely to HDMI device ports to minimize signal disruptions, and is ideal for critical A/V setups such as security systems and HDMI switches This High Speed HDMI Cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Gold-plated connectors are rated to operate beyond 10,000 insertions. The HDMI Monitor Cable supports full HDMI 2.0 features, including resolutions up to 4K 60Hz using a compatible HDMI source and display, high refresh rates including 1440p 144Hz and 1080p 240Hz, 21:9 Aspect Ratio, High Dynamic Range (HDR10) for higher contrast ratio, High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display, Audio Return Channel (ARC), Up to 32 Uncompressed Digital Audio Channels, HDMI Ethernet Channel (HEC) for network connectivity over HDMI, and backward compatible with previous HDMI versions. This HDMI 2.0 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
