            The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
        Customer reviews
                Write a review for the StarTech.com DVI to VGA Cable Adapter - M/F here!
            Good Stuff
                By
                        M@ Morgan.
Posted
                20/01/2007
            Does what it says!
                By
                        Matt.
Posted
                14/02/2007
            The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
