Easily convert your dual monitor workstation into a standing desk for greater comfort and productivity. This wall-mounted sit-stand desk for dual monitors is perfect for areas that don't have enough space for a traditional sit-stand desk. Its compact, wall-mounted design combines a dual-monitor arm and a keyboard tray, with easy height adjustments that let you alternate between sitting and standing without disrupting your workflow.
Adjust your working position in one smooth motion. Simply lift the work surface up to 17.2" (436 mm), to elevate your monitor, keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports two monitors up to 24" (with weight capacity of 17.6 lb./8 kg). Adjust your monitor for ideal viewing, with -15° to +15° swivel and 0° to 30° tilt, or rotate your monitors up to 360° for portrait or landscape orientation.
The sit-stand desk folds back to the wall, and the keyboard tray folds up to 90°, saving space when not in use. You can move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to make maximum use of your space.
The monitor arm offers plenty of work space, with a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) and a slide-out tray (8.5 x 8.4" / 217 x 213 mm) that holds your mouse, on the left or right.
