Mount two displays on your desk surface or through a grommet, with adjustable height and cable management. The ARMDUAL Articulating Dual Monitor Arm lets you mount two displays to your desk or table, with extension, tilt, pan, swivel, pivot and height adjustments.
The desk-mount monitor arm offers a wide range of motion on several axes, giving you the freedom to place your displays side-by-side, spread apart, back-to-back or anywhere in between. For viewing longer pages or blocks of code without scrolling, the dual arm also supports landscape to portrait display rotation for either monitor.
Mounting your displays on a dual monitor arm above the desk surface enables you to adjust your display height, position and viewing angles easily for an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk.
Supporting 12 - 24" displays up to a maximum weight capacity of 30lbs (13.6kg) per arm, the dual arm monitor mount holds your displays with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole, for a versatile dual-monitor mounting solution.
StarTech.com Dual Monitor Mount - Articulating Arms -...![]() In Stock £208.63 |
StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVIIn Stock£102.22 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with AudioIn Stock£90.65 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk MountIn Stock£109.46 |
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPortIn Stock£120.39 |
StarTech.com Docking Station for 2 LaptopsIn Stock£156.24 |
StarTech.com Sit-to-Stand WorkstationIn Stock£192.38 |
StarTech.com Monitor Mount - USB PassthroughIn Stock£128.09 |
StarTech.com Dual Monitor Mount - StackableIn Stock£146.29 |
StarTech.com Dual Monitor StandIn Stock£69.36 |
StarTech.com USB-C Laptop Dock - MST and PDIn Stock£106.51 |
