Quicklinx: | FVKPWS00 |
Mfr#: | ARMSLIMDUOS |
Dual Articulating Monitor Arm VESA 75x75 100x100 Height Adjustable For up to 32" Monitors. Enhance productivity and free up valuable space with the desk mount dual monitor arm. Two independent arms make it easy to adjust your dual-monitor setup.
Built-in USB Pass-Through Ports and Audio Ports
The ARMSLIMDUOS provides easy access to two USB pass-through ports and two audio ports located at the front of the base. The ports let you plug in your microphone, headset or USB devices, without having to reach for your computer.
Full-Motion Arms with Articulation and Spring-assisted Height Adjustment
The desk-mount monitor arms offer a full range of motion on several axes, letting you tilt, pan and rotate your monitors to adjust your viewing angle. The dual-arm monitor mount holds two 15" to 32" monitors and each arm supports up to 8.0 kg (17.6 lb.) of weight.
Durable Construction and Easy Setup
With its durable aluminum construction and stylish silver finish, the ARMSLIMDUOS securely holds two monitors using a standard VESA 75x75 and 100x100 mount.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
ARMSLIMDUOS is backed by a StarTech.com 2-year warranty and free lifetime technical support.
