Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 6 ft DVI-D Single Link Cable - M/MIn Stock£6.86 |
StarTech.com 15 ft DVI-D Single Link Cable - M/MIn Stock£13.72 |
StarTech.com 6 ft DVI-D Dual Link Cable - M/MIn Stock£6.78 |
StarTech.com 10 ft DVI-D Dual Link Cable - M/MIn Stock£10.72 |
StarTech.com DisplayPort to DVI Video Adapter ConverterIn Stock£15.63 |
StarTech.com DisplayPort DVI Video Adapter ConverterIn Stock£13.69 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/MIn Stock£33.42 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/MIn Stock£27.03 |
StarTech.com DisplayPort to DVI Video Adapter ConverterIn Stock£10.18 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/MIn Stock£15.53 |
StarTech.com 10 ft DVI-D Single Link Cable - M/MIn Stock£7.98 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/FIn Stock£18.55 |
StarTech.com DisplayPort to DVI Active AdapterIn Stock£22.04 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600In Stock£95.60 |
