This composite to VGA video converter provides a simple way to convert and scale composite and S-Video signals to VGA output, for use with computer monitors, projectors or HDTV sets.
Equipped with an on-screen display (OSD) menu and a toggle switch for simple configuration and selection of your video output settings, this compact S-Video to VGA video converter installs quickly and easily, for a true plug-and-play experience.
By using this AV to VGA adapter you'll be able to continue using your legacy equipment (VCR, DVD player, etc.) with your VGA display or monitor, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching old home videos on your VGA display or new HDTV.
The AV to VGA converter features an integrated video scaler circuit that dynamically converts the S-Video or composite video input signal, giving you multiple output resolutions to choose from, to ensure compatibility with your display or projector. It supports resolutions up to 1920x1200 @ 60Hz, so you can enjoy high-definition video without having to sacrifice picture quality.
